[QGIS-Developer] QGIS Server 2.x: issue with @map_scale variable vs. $scale
Andreas Neumann
a.neumann at carto.net
Tue Jul 4 23:38:17 PDT 2017
Hi Nyall,
Thanks for explaining this. Makes sense and glad that it will be fixed
in QGIS 3.
So my follow-up question is: can I rely on $scale to work in future
version of QGIS or will it be deprecated?
Andreas
On 05.07.2017 00:52, Nyall Dawson wrote:
> On 4 July 2017 at 01:46, Neumann, Andreas <a.neumann at carto.net> wrote:
>> Hi,
>> In a QGIS project that should be published with QGIS Server, I used the
>> @map_scale variable to define the font size with an expression, depending on
>> the map scale. It works fine on QGIS Desktop, but on QGIS server GetMap
>> requests it fails - the font-size (defined in map units) is constant and
>> doesn't react to my scale dependent rule. The interesting thing, is, that
>> the same rule works fine in GetPrint requests.
>> If I change my rule to use $scale instead of @map_scale, my label rule works
>> fine.
>> Could it be that the @map_scale variable doesn't work in QGIS server GetMap
>> requests?
> Exactly - it's a consequence of QGIS 2.x server using the really old
> map renderer, which means it doesn't have access to any variables
> relating to the current map scale/extent/etc. This is also why 2.5d
> renderer is quite broken on server under 2.x.
> The good news is that it's all fixed with 3.0.
> Nyall
>> Here is my expression:
>> CASE
>> WHEN @map_scale <= 251 THEN 1
>> WHEN @map_scale > 251 AND @map_scale <= 501 THEN 2
>> WHEN @map_scale > 501 AND @map_scale <= 1001 THEN 3
>> WHEN @map_scale > 1001 AND @map_scale <= 2001 THEN 4
>> WHEN @map_scale > 2001 AND @map_scale <= 3001 THEN 6
>> WHEN @map_scale > 3001 AND @map_scale <= 4001 THEN 7
>> WHEN @map_scale > 4001 THEN 8
>> END
>> Thanks for your ideas.
>> Andreas
>> QGIS-Developer mailing list
>> QGIS-Developer at lists.osgeo.org
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
