[QGIS-Developer] QGIS/OGR: FeatureIds reassigned on write to data provider?
Matthias Kuhn
matthias at opengis.ch
Wed Jul 5 02:55:09 PDT 2017
On 7/5/17 1:31 AM, Nathan Woodrow wrote:
> > I'd say we definitely do in the processing case. It'd be a significant
> shortcoming to have to manually unload layers from projects before you
> can run analysis on them.
> > Not sure about totally external applications though....
> My comments only relate to external applications using files we have
> open, I guess having it open in two QGIS instances is the same issue.
> But I get the same thing if I open the same word doc twice one of the
> applications will take a write lock on the file.
It's not about a write lock here, but about files that are written with
"incompatible" data and therefore also fail to be opened in read only mode.
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20170705/2df39bc4/attachment.html>
