[QGIS-Developer] UI Master: Empty Vector Toolbar? + Tooltips bold	or not?
    Richard Duivenvoorde
    rdmailings at duif.net
    Thu Jul  6 02:34:09 PDT 2017
Doing a fresh compile, I have an very emtpy 'Vector Toolbar' (handle) in
my toolbar section. Is it still used, or will/can it be filled by
plugins. If not we/I can remove it?
I used hovering over the handle to see the tooltip to see the name of
the toolbar, and then mentioned that some of the tooltips are in Bold,
while others are not.
For example:
- in the Project Toolbar all is bold
- the Snapping Toolbar (which does not even have a tooltip) is normal font
- all the widgets in the statusbar have normal font
Easy to fix? Or is this stylesheet related?
Regards,
ps also checked on Windooz, is the same.
