[QGIS-Developer] [Qgis-developer] gdalogr-Processing in QGIS 3.0
Nyall Dawson nyall.dawson at gmail.com
Thu Jul 6 23:14:07 PDT 2017
On 7 July 2017 at 16:09, EZUSoft <qgis at makobo.de> wrote:
> Hi @all,
> with the weekly build from february this code works:
> import processing
> processing.runalg('gdal:convertformat',"d:/test/mydxf.dxf", 0, opt ,
> "d:/test/myshp.shp")
> Now I test the weekly build "c1d339c"  and it does not work:
> Error: AttributeError: module 'processing' has no attribute 'runalg'
This is all in a state of flux. In QGIS 3.0 you would do something like:
processing.run( 'gdal:convertformat', {'INPUT':"d:/test/mydxf.dxf",
... , 'OUTPUT':'d:/test/myshp.shp'} )
i.e. you know use a dict for specifying the options.
But gdal algorithms are not available yet - only a handful of qgis ones.
Nyall
> Unfortunately, I found in the net no example how to use the new version of
> the processing for (ogr) convert dxf to shape.
> Greatings Mike
> EZUSoft <qgis at makobo.de> hat am 27. März 2017 um 16:56 geschrieben:
> Hi,
> thanks for answer.
> processing.runalg('gdal:convertformat' ...
> This works (in the principle).
> Greatings Mike
> DelazJ <delazj at gmail.com> hat am 27. März 2017 um 10:41 geschrieben:
> Hi,
> It's because gdalogr no longer exists in 3.0, use instead gdal. You could to
> run processing.alglist() to get the write syntax of functions.
> Regards,
> Harrissou
> 2017-03-27 9:05 GMT+02:00 EZUSoft <qgis at makobo.de>:
> Hi @all,
> i can not use the "gdalogr"-Processing in QGIS 3.0 (2.99) QGIS code revision
> 1182816
> import processing
> processing.runalg('gdalogr:convertformat','', 0, '' ,'')
> Error: Algorithm not found
> Does anyone know whats going wrong?
> Greatings Mike
> Qgis-developer mailing list
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
More information about the QGIS-Developer mailing list
