[QGIS-Developer] [Qgis-developer] gdalogr-Processing in QGIS 3.0
EZUSoft qgis at makobo.de
Fri Jul 7 00:56:20 PDT 2017
thank you for the fast answer.
It makes then current no sense  to develop my plugins further.
Greatings Mike
> Nyall Dawson <nyall.dawson at gmail.com> hat am 7. Juli 2017 um 08:14 geschrieben:
> This is all in a state of flux. In QGIS 3.0 you would do something like:
> processing.run( 'gdal:convertformat', {'INPUT':"d:/test/mydxf.dxf",
> ... , 'OUTPUT':'d:/test/myshp.shp'} )
> i.e. you know use a dict for specifying the options.
> But gdal algorithms are not available yet - only a handful of qgis ones.
> Nyall
> > Unfortunately, I found in the net no example how to use the new version of
> > the processing for (ogr) convert dxf to shape.
> > Greatings Mike
> > EZUSoft <qgis at makobo.de> hat am 27. März 2017 um 16:56 geschrieben:
> > Hi,
> > thanks for answer.
> > processing.runalg('gdal:convertformat' ...
> > This works (in the principle).
> > Greatings Mike
> > DelazJ <delazj at gmail.com> hat am 27. März 2017 um 10:41 geschrieben:
> > Hi,
> > It's because gdalogr no longer exists in 3.0, use instead gdal. You could to
> > run processing.alglist() to get the write syntax of functions.
> > Regards,
> > Harrissou
> > 2017-03-27 9:05 GMT+02:00 EZUSoft <qgis at makobo.de>:
> > Hi @all,
> > i can not use the "gdalogr"-Processing in QGIS 3.0 (2.99) QGIS code revision
> > 1182816
> > import processing
> > processing.runalg('gdalogr:convertformat','', 0, '' ,'')
> > Error: Algorithm not found
> > Does anyone know whats going wrong?
> > Greatings Mike
> > Qgis-developer mailing list
> > Qgis-developer at lists.osgeo.org
> > List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> > Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> > QGIS-Developer mailing list
> > QGIS-Developer at lists.osgeo.org
More information about the QGIS-Developer mailing list
