[QGIS-Developer] QGIS 3 > Processing: some test
Nyall Dawson nyall.dawson at gmail.com
Thu Jul 6 23:41:25 PDT 2017
On 4 July 2017 at 17:57, matteo <matteo.ghetta at gmail.com> wrote:
> Hi Nyall,
>>>>> * barplot does not return a result (result viewer is empty)
>>>> Looks like this happens when you don't pick a destination file.  Can
>>>> you re-test and explicitly choose an output file.
>>> tried, still empty wpanel
> I notice that with all the algorithm that return html outputs, the
> result viewer is empty and one can get the result just by saving the
> output as local html in a folder.
Fixed in master - the issue was missing file extensions.
Note that the "basic stats" algorithm now no longer outputs the html
by default. It's now an optional output, so you either need to
manually set a location for it, or click the "..." button and choose
"save to a temporary file" for it to be generated.
Otherwise the results are only visible in the algorithm execution log
(and models)
Nyall
More information about the QGIS-Developer mailing list
