[QGIS-Developer] QGIS 3 > Processing: some test
matteo
matteo.ghetta at gmail.com
Fri Jul 7 00:51:54 PDT 2017
> Fixed in master - the issue was missing file extensions.
confirmed also this fix.
> Note that the "basic stats" algorithm now no longer outputs the html
> by default. It's now an optional output, so you either need to
> manually set a location for it, or click the "..." button and choose
> "save to a temporary file" for it to be generated.
> Otherwise the results are only visible in the algorithm execution log
> (and models)
may I ask if there is a reason for not create the memory html by default
putting it in the Results Viewer?
IMHO, many many users will expect to see the statistics somewhere by default
Thanks
Matteo
