[QGIS-Developer] Processing tests.. continuing...
matteo
matteo.ghetta at gmail.com
Fri Jul 7 00:59:55 PDT 2017
> I can't reproduce. Can you set the processing setting to keep the
> algorithm dialog open after execution, and copy and paste the log
> contents here?
same problem for the other algorithm. Hitting tab or clicking in another
box will reset the field to the default value.
sorry for the noise
> (we really should make the processing history panel show this log too!)
>> moreover, I think that the current "buffer" algorithm should melt the
>> old "fixed" and "variable" buffer ones. But when a layer is selected in
>> the combobox and instead of adding a number for the buffer, one wants to
>> select a field, by opening the Expression Widget, no fields appear in
>> the menu "Fields and Values".
> Ideally yes. It supports both use cases, but they aren't exposed in
> the GUI (and I don't have plans to implement this UI for 3.0). It's
> one of the (many) new features in processing which are currently API
> only.
perfectly clear
> So for now this is just a demo algorithm, which will probably be
> hidden when the fixed distance/variable distance buffer algs are
> ported across.
So the fixed/variable distance algorithms will be restored until the
native buffer is ready to replace both of them?
Thanks
Matteo
