[QGIS-Developer] Processing tests.. continuing...
Nyall Dawson nyall.dawson at gmail.com
Fri Jul 7 01:09:09 PDT 2017
On 7 July 2017 at 17:59, matteo <matteo.ghetta at gmail.com> wrote:
>> I can't reproduce. Can you set the processing setting to keep the
>> algorithm dialog open after execution, and copy and paste the log
>> contents here?
> same problem for the other algorithm. Hitting tab or clicking in another
> box will reset the field to the default value.
> sorry for the noise
Hmmm. I've seen other reports of this nature, but not sure what causes
it (it's not processing specific). Do you have the QGIS Qt custom
widgets plugin installed by any chance?
>> So for now this is just a demo algorithm, which will probably be
>> hidden when the fixed distance/variable distance buffer algs are
>> ported across.
> So the fixed/variable distance algorithms will be restored until the
> native buffer is ready to replace both of them?
Yep.
Nyall
More information about the QGIS-Developer mailing list
