[QGIS-Developer] QGIS/OGR: FeatureIds reassigned on write to data provider?
Sandro Mani
manisandro at gmail.com
Mon Jul 10 04:30:58 PDT 2017
On 06.07.2017 11:00, Sandro Mani wrote:
> On 06.07.2017 10:57, Even Rouault wrote:
>> On jeudi 6 juillet 2017 10:45:21 CEST Sandro Mani wrote:
>> > On 05.07.2017 14:56, Sandro Mani wrote:
>> > >> That could potentially be done using the current OGR API. Basically
>> > >> in pseudo code, to execute before executing REPACK
>> > >> OGR_L_ResetReading(layer)
>> > >> char** ignored_fields = CSLAddString(NULL, "OGR_GEOMETRY" );
>> > >> OGR_L_SetIgnoredFields( layer, ignored_fields); // for performance.
>> > >> CSLDestroy(ignored_fields);
>> > >> OGR_L_SetAttributeFilter( layer, NULL )
>> > >> OGR_L_SetSpatialFilter( layer, NULL )
>> > >> std::map<GIntBig, GIntBig> mapOldIdToNewId;
>> > >> GIntBig newId = 0;
>> > >> while( feature = OGR_L_GetNextFeature(layer) )
>> > >> mapOldIdToNewId[OGR_F_GetFID(feature)] = newId;
>> > >> newId ++;
>> > >> OGR_F_destroy(feature);
>> > >> OGR_L_SetIgnoredFields( layer, NULL );
>> > > Ok cool, that sounds like a plan - I'll give it a shot.
>> > Hmm so while on the provider side it works well, for the geometry
>> > checker it is turning out to be pretty hard to deal with the changing
>> > feature ids (just to cite one example: error fixed by merging geometry
>> > of feature 10 with that of 11, results in {deleted: 10, updated: 11},
>> > but after the feature id adjustment this would read {deleted: 10,
>> > updated: 10}, meaning one would need to keep track that deleted: 10
>> > refers to the old featureid). Not saying that it isn't doable, but the
>> > complexitiy of properly handling the feature id changes is non-trivial.
>> > So, other suggestion: any objections if I add a method to
>> > QgsVectorDataProvider to temporarily freeze repacking? I could also add
>> > a notification informing the user that the shapefile should not be used
>> > in other applications while repacking is frozen.
>> My feeling is that QgsOgrDataProvider is already complicated enough
>> with its existing tricks. I'm not sure this temporary freeze
>> repacking is a right move (how would you decide when you do it ? and
>> I'm pretty sure users will not get it, or will have issues if they
>> start an algorithm with an external tool that requires packed shapefiles)
> It would be something I would call explicitly while the geometry
> checker is active, I think it is safe to assume that users don't
> expect that they can operate on the shapefile while the geometry
> checker is processing it. It would not add much complexity to the
> provider, just a flag that repacking is frozen, and a setter to set
> that flag. When the flag is set to false, the shapefile is repacked.
I did some playing around and came up with some FeatureId mapping code
which is pretty space efficient (basically requiring just
3*nDeletedFeatures entries), see below.
The code however assumes that the gaps in the fid-sequence are filled by
decreasing the fids after the gap, which may be pretty specific to the
OGR/Shapefile behaviour. Hence in my view such code should really belong
into the OGR provider (or perhaps even ogr itself) and not in the
plugin. Thoughts?
Sandro
#include <algorithm>
#include <iostream>
#include <QMap>
#include <QVector>
typedef int QgsFeatureId;
class FeatureMapping {
public:
QgsFeatureId stableToProvider(QgsFeatureId stableId) const
if(mDeletedStableIds.contains(stableId)){
return -1;
// providerId = stableId - nDeletedBeforeStableId
int nDeletedBeforeStableId = std::lower_bound(mDeletedStableIds.begin(), mDeletedStableIds.end(), stableId) - mDeletedStableIds.begin();
return stableId - nDeletedBeforeStableId;
QgsFeatureId providerToStable(QgsFeatureId providerId) const
int i = 0, n = mProviderToStableOffsetKeys.size(), offset = 0;
while(i < n && mProviderToStableOffsetKeys[i] <= providerId) {
offset += mProviderToStableOffsetValues[i++];
return providerId + offset;
void updateFeatureIdMap(const QList<QgsFeatureId> &deletedIds)
for(QgsFeatureId fid : deletedIds) {
mDeletedStableIds.append(providerToStable(fid));
std::sort(mDeletedStableIds.begin(), mDeletedStableIds.end());
int n = mProviderToStableOffsetKeys.size();
int pos = std::lower_bound(mProviderToStableOffsetKeys.begin(), mProviderToStableOffsetKeys.end(), fid) - mProviderToStableOffsetKeys.begin();
if(pos < n && mProviderToStableOffsetKeys[pos] == fid) {
mProviderToStableOffsetValues[pos] += 1;
} else {
mProviderToStableOffsetKeys.insert(pos, fid);
mProviderToStableOffsetValues.insert(pos, 1);
++n;
if(pos + 1 != n && mProviderToStableOffsetKeys[pos+1] -1 == fid) {
mProviderToStableOffsetValues[pos] += mProviderToStableOffsetValues[pos+1];
mProviderToStableOffsetKeys.removeAt(pos + 1);
mProviderToStableOffsetValues.removeAt(pos + 1);
--n;
++pos;
while(pos < n) {
mProviderToStableOffsetKeys[pos++] -= 1;
std::cout << "offsets = {";
for(int i = 0, n = mProviderToStableOffsetKeys.size(); i < n; ++i) {
std::cout << mProviderToStableOffsetKeys[i] << ": " << mProviderToStableOffsetValues[i] << ", ";
std::cout << "\b\b}" << std::endl;
int numDeleted() const{ return mDeletedStableIds.size(); }
private:
QVector<QgsFeatureId> mProviderToStableOffsetKeys;
QVector<int> mProviderToStableOffsetValues;
QVector<QgsFeatureId> mDeletedStableIds;
void printMapping(const FeatureMapping& mapping) {
std::cout << "------" << std::endl;
for(int i = 0; i < 10; ++i) {
std::cout << i << " -> " << mapping.stableToProvider(i) << std::endl;
for(int i = 0, n = 10 - mapping.numDeleted(); i < n; ++i) {
std::cout << mapping.providerToStable(i) << " <- " << i << std::endl;
int main(int argc, char* argv[]){
FeatureMapping mapping;
printMapping(mapping);
while(true) {
std::cout << "> ";
std::string command;
std::getline(std::cin, command);
if(command.empty()) {
continue;
}else if(command[0] == 'q') {
break;
}else if(command[0] == 'd') {
QgsFeatureId num = std::atoi(command.substr(1).c_str());
std::cout << "* Delete: stable " << num << ", provider: " << mapping.stableToProvider(num) << std::endl;
mapping.updateFeatureIdMap({mapping.stableToProvider(num)});
} else {
std::cout << "Unknown command" << std::endl;
return 0;
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20170710/c57458cf/attachment-0001.html>
