[QGIS-Developer] About dialogue: QGIS code revision vs QGIS code branch
Neumann, Andreas
a.neumann at carto.net
Mon Jul 17 08:22:37 PDT 2017
Hi Jürgen,
I updated some system libs (C-stuff) in Kubuntu and now QGIS starts
again without a crash. The code revision displays fine again.
So apparently it was a temporary problem in my local system and is fixed
now.
Thanks again,
Andreas
On 2017-07-17 17:07, Neumann, Andreas wrote:
> Hi Jürgen,
> thx for the fix.
> Unfortunately I now get a crash during startup after I compiled the newest version ;-)
> QGIS died on signal 11. Could not attach to process. There is some more stuff in the error message. Not sure if it is relevant.
> I did a "ninja clean" to make sure there is no old stuff around that may cause the crash.
> Andreas
> On 2017-07-17 15:32, Jürgen E. Fischer wrote:
> Hi Andreas,
> On Mon, 17. Jul 2017 at 14:16:36 +0200, Neumann, Andreas wrote: I noticed, on another machine, a self compiled QGIS, that I don't see
> the code revision, but it only displays a "QGIS code branch" instead,
> with "Release 2.99" as the value.
> Please verify with bcc8e90640d.
> Jürgen
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20170717/9833300e/attachment.html>
