[QGIS-Developer] two issues in QGIS (Server and print composer) 2.18.10(?)
Giovanni Manghi
giovanni.manghi at gmail.com
Thu Jul 20 09:23:53 PDT 2017
On Thu, Jul 20, 2017 at 5:01 PM,
<qgis-developer-request at lists.osgeo.org> wrote:
> Send QGIS-Developer mailing list submissions to
> qgis-developer at lists.osgeo.org
> 5. two issues in QGIS (Server and print composer) 2.18.10(?)
> (Giovanni Manghi)
> 2) was the option "none" for the "map" option of a legend object in
> print composer removed on purpose from 2.18(.10)? I still see it in
> 2.14.16 and it was *very important* to get "fixed" legends -via
> GetPrint- in QGIS Server. If it was removed by design I suppose there
> is another way to achieve that in 2.18... some can point me to it? If
> the option was just removed and I'm not missing anything then now via
> GetPrint is not possible to have layouts printed with "fixed" legends
> (the layer name appears, not its symbology class/es).
> see the following two examples.
> The first is the result of a getprint from a project saved within 2.14
> where the legend option "map" was set to "none"
> https://www.dropbox.com/s/f1jtr2i8qfbm5sw/qgis_server_with_none_option.pdf?dl=0
> The second is the result of a getprint from a project saved within
> 2.18 where the legend option "map" was set to "map0" because there is
> no "none" option (or within 2.14 setting always the option to "map0")
> https://www.dropbox.com/s/svgbmx8sor7jjuz/qgis_server_without_none_option.pdf?dl=0
> both requests were made via QGIS Server 2.18 using a project with
> several layers but actually only one was added in the request (using
> Lizmap demo project here if anyone is interested):
> http://localhost/cgi-bin/qgis_mapserv.fcgi?map=/path/to/my/project.qgs&SERVICE=WMS&VERSION=1.3.0&REQUEST=GetPrint&FORMAT=pdf&TRANSPARENT=true&SRS=EPSG:3857&DPI=100&TEMPLATE=Landscape%20A4&map0:extent=420232.0463583274,5395327.438198717,443932.6162906727,5414427.897511283&map0:scale=100000&map0:LAYERS=points%20of%20interest&LAYERS=points%20of%20interest
actually the result of the GetPrint (with the above request) when the
project is saved in 2.18 is this one
https://www.dropbox.com/s/hfsvul4uy3h5uqa/qgis_server_without_none_option_2_18.pdf?dl=0
and the legend shows "?" in place of layer names (see above). So I
really think this is a regression possibly caused by the removal of
this "none" option.
I would appreciate if any QGIS Server/map composer dev can chime in here.
cheers
-- G --
