[QGIS-Developer] QGIS 2.18 Windows build problems
David Adler dadler at adtechgeospatial.com
Fri Jul 21 06:52:26 PDT 2017
I'm still having problems building on Windows 7 using VS 2010 after
running cmake-gui with errors like:
43>    File "J:\QGISDB2-218\scripts\\pyuic-wrapper.py", line 26, in <module>
43>      import qgis.PyQt.uic.pyuic
43>    File "E:\qgisbuild\output\python\qgis\__init__.py", line 27, in
<module>
43>      from qgis.core import QgsFeature, QgsGeometry
43>    File "E:\qgisbuild\output\python\qgis\core\__init__.py", line 30,
in <module>
43>      from qgis._core import *
43>  ImportError: DLL load failed: The specified module could not be found.
48>    File "J:\QGISDB2-218\scripts\\pyuic-wrapper.py", line 26, in <module>
43>C:\Program Files
(x86)\MSBuild\Microsoft.Cpp\v4.0\Microsoft.CppCommon.targets(151,5):
error MSB6006: "cmd.exe" exited with code 1.
48>      import qgis.PyQt.uic.pyuic
57>------ Build started: Project: zzz-processing-66-depend,
Configuration: RelWithDebInfo Win32 ------
48>    File "E:\qgisbuild\output\python\qgis\__init__.py", line 27, in
<module>
48>      from qgis.core import QgsFeature, QgsGeometry
48>    File "E:\qgisbuild\output\python\qgis\core\__init__.py", line 30,
in <module>
48>      from qgis._core import *
48>  ImportError: DLL load failed: The specified module could not be found.
48>C:\Program Files
and
----- Build started: Project: zzz-db_manager-stageinstall,
74>  CMake Error at
E:/qgisbuild/python/plugins/db_manager/stageinstall.cmake:30 (FILE):
74>    file COPY cannot find
74>
"E:/qgisbuild/python/plugins/db_manager/db_plugins/postgis/plugins/versioning/ui_DlgVersioning.py".
Is there something obvious that needs to be changed? I'm completely
stuck until I get past this.
This email has been checked for viruses by Avast antivirus software.
https://www.avast.com/antivirus
More information about the QGIS-Developer mailing list
