[QGIS-Developer] Problem with "no Data value" with rasters when using the Layer Styling panel?
Stéphane Henriod
stephanebek at gmail.com
Thu Jun 1 02:36:05 PDT 2017
Hi again
in doubt, I have opened a ticket here: https://issues.qgis.org/issues/16649
Cheers
Stéphane
Le mardi 30 mai 2017, Stéphane Henriod <stephanebek at gmail.com> a écrit :
> PS: screencast to better explain the issue: https://vimeo.com/219467091
> <javascript:_e(%7B%7D,'cvml','stephanebek at gmail.com');>> a écrit :
>> Hi
>> I am testing the layer styling panel (shortcut F7) with the latest
>> Nightly build on the Ubuntu repositories.
>> By default, the NoData value is -9999. If I add "10" as additional NoData
>> value, nothing happens.
>> If I do the same in the layer properties, then the expected behavior
>> happens: all pixels with value "10" are not rendered.
>> So it seems that the manually added NoData values in the Layer Styling
>> Panel are not considered.
>> Can someone else replicate this problem? Should I open a ticket?
>> Cheers
>> Stéphane
>> “When you travel, remember that a foreign country is not designed to make
>> you comfortable. It is designed to make its own people comfortable." --
>> Clifton Fadiman
> Clifton Fadiman
Clifton Fadiman
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20170601/60e4734f/attachment.html>
