[QGIS-Developer] Problem with "no Data value" with rasters when using the Layer Styling panel?
Stéphane Henriod
stephanebek at gmail.com
Tue Jun 20 14:17:18 PDT 2017
Hi all
Apparently, this has been confirmed as a bug. Is anyone willing / able to
take care of it?
Thanks a lot and cheers
Stéphane (who really feels sorry to raise such questions, while not being
able himself to actively contribute to the resolution of such bugs)
Le jeudi 1 juin 2017, Stéphane Henriod <stephanebek at gmail.com> a écrit :
> Hi again
> in doubt, I have opened a ticket here: https://issues.qgis.org/
> issues/16649
> Cheers
> Stéphane
> Le mardi 30 mai 2017, Stéphane Henriod <stephanebek at gmail.com
> <javascript:_e(%7B%7D,'cvml','stephanebek at gmail.com');>> a écrit :
>> PS: screencast to better explain the issue: https://vimeo.com/219467091
>> Le mardi 30 mai 2017, Stéphane Henriod <stephanebek at gmail.com> a écrit :
>>> Hi
>>> I am testing the layer styling panel (shortcut F7) with the latest
>>> Nightly build on the Ubuntu repositories.
>>> By default, the NoData value is -9999. If I add "10" as additional
>>> NoData value, nothing happens.
>>> If I do the same in the layer properties, then the expected behavior
>>> happens: all pixels with value "10" are not rendered.
>>> So it seems that the manually added NoData values in the Layer Styling
>>> Panel are not considered.
>>> Can someone else replicate this problem? Should I open a ticket?
>>> Cheers
>>> Stéphane
>>> “When you travel, remember that a foreign country is not designed to
>>> make you comfortable. It is designed to make its own people comfortable."
>>> -- Clifton Fadiman
>> “When you travel, remember that a foreign country is not designed to make
>> you comfortable. It is designed to make its own people comfortable." --
>> Clifton Fadiman
> Clifton Fadiman
Clifton Fadiman
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20170620/9ff18d1b/attachment-0001.html>
