[QGIS-Developer] [Qgis-developer] Are there plans to create a unique "Add layer" tool?
Alessandro Pasotti apasotti at gmail.com
Mon Jun 5 00:59:30 PDT 2017
On Mon, Jun 5, 2017 at 9:50 AM, Ismail Sunni <imajimatika at gmail.com> wrote:
> Hi Allesandro,
> I just tried the new add layer button. It looks great! One thing that I
> found, when I click the add layer button in the browser panel, there is
> nothing happening.
> I made a gif to show it : http://imgur.com/EPGFuEz
Works for me. Make sure you selected a layer before pushing that button.
> I build QGIS master on MacOS, for 27850fb00e
> Best regards.
> On Mon, Jun 5, 2017 at 1:51 PM, Alessandro Pasotti <apasotti at gmail.com>
> wrote:
>> Hi Stéphane,
>> Thanks for testing the new dialog!
>> I think that if you find a bug (a crash or something that doesn't work as
>> expected) you should open an issue on the hub and assign it to me.
>> For general feed-back or change proposal for the UI/UX you can either use
>> this thread or make a PR with the proposed changes and discuss them in the
>> the PR.
>> Cheers
>> On Sun, Jun 4, 2017 at 8:14 PM, Stéphane Henriod <stephanebek at gmail.com>
>> wrote:
>>> Hi Alessandro
>>> I just downloaded the latest nightly build and will make some tests in
>>> the coming days. What would be the most efficient / useful way to give you
>>> feedback and comments? On this thread?
>>> Thanks and cheers
>>> Stéphane
>>> Le jeudi 1 juin 2017, Alessandro Pasotti <apasotti at gmail.com> a écrit :
>>>> On Thu, Jun 1, 2017 at 11:22 AM, Stéphane Henriod <
>>>> stephanebek at gmail.com> wrote:
>>>>> I really look forward to testing it :-) Thanks a lot for our
>>>>> involvement here!
>>>> Thanks to Boundless for funding the development and thanks to all of
>>>> you who participated with design, mockups, ideas, comments and reviews!
>>>> This was a nice and effective cooperation.
>>>> BTW, if you can't wait, a Docker with a nigthly build of the PR branch
>>>> is available as "boundlessgeo/qgis-testing-environment:unified-button"
>>>> Cheers
>>>>> Le mercredi 31 mai 2017, Alessandro Pasotti <apasotti at gmail.com> a
>>>>> écrit :
>>>>>> Hi,
>>>>>> final update: the development of what was in phase 1 is done.
>>>>>> Actually, a bit more than phase 1 considering that we've redesigned
>>>>>> the delimited text dialog GUI and I've done quite a bit of small
>>>>>> refactorings of the providers selection dialogs interfaces.
>>>>>> There has been a lot of feed-back, thank you all!
>>>>>> As expected, there is no complete agreement over the final GUI bits
>>>>>> for the menus and toolbars, and we still miss an icon (the green plus that
>>>>>> I've used was only meant as a placeholder). I tried to keep the old toolbar
>>>>>> available (disabled by default) mainly because it can spare a click and
>>>>>> power users might want it back. Also, the new icon is the most prominent in
>>>>>> the left bar and it's the first menu item in the layers menu.
>>>>>> I have not a strong opinion about those toolbars and menus but I
>>>>>> think I should wait no more and merge it as it is, then give the people
>>>>>> some time to test the actual implementation and decide how to improve it.
>>>>>> I kept the controversial part in a single commit so that it will be
>>>>>> very easy to revert and propose a different placement for menus, icons and
>>>>>> toolbars.
>>>>>> Any objections if I proceed?
>>>>>> On Wed, May 24, 2017 at 2:29 PM, Alessandro Pasotti <
>>>>>> apasotti at gmail.com> wrote:
>>>>>>> Hi,
>>>>>>> a quick update:
>>>>>>> I've prepared a PR with a working prototype in
>>>>>>> https://github.com/qgis/QGIS/pull/4629, I need some feed-back and
>>>>>>> some help, expecially UX/UI about if we want it as a dockable dialog too
>>>>>>> (and how to make it user-configurable).
>>>>>>> Feed-back welcome (but please keep it limited in scope to phase 1).
>>>>>>> Cheers
>>>>>>> On Fri, May 19, 2017 at 9:45 AM, Richard Duivenvoorde <
>>>>>>> rdmailings at duif.net> wrote:
>>>>>>>> On 19-05-17 01:23, Nyall Dawson wrote:
>>>>>>>> > On this note - I've recently discovered the need for some type of
>>>>>>>> > reusable layer selection widget which allows choice of existing
>>>>>>>> > layers/loading new layers from the file system/loading new layers
>>>>>>>> from
>>>>>>>> > available db/online connections. This would be extremely valuable
>>>>>>>> for
>>>>>>>> > processing too!
>>>>>>>> > So I'm really glad to hear that you'll be pushing ahead with this
>>>>>>>> work
>>>>>>>> > - thanks Boundless!
>>>>>>>> Yep, and thanks Alessandro for the screenie. Makes me want more!
>>>>>>>> @Nyall in Essen the talk was to start with what Alessandro wrote in
>>>>>>>> his
>>>>>>>> email, so 1 dialog 'merging' all buttons/widgets/dialogs into one,
>>>>>>>> reuse
>>>>>>>> as much as possible. So it was possible to get it into 3.0
>>>>>>>> Off course people (.../me) started brainstorming about features
>>>>>>>> which
>>>>>>>> w/could be added too :-)
>>>>>>>> Your idea adds (I think) to the idea to make some kind of
>>>>>>>> 'datamanagement-console' in near future, where you can create/copy
>>>>>>>> data(!), move data around (browser part) or delete it.
>>>>>>>> Your note fits in this isn't it?
>>>>>>>> Regards,
>>>>>>>> Richard
>>>>>>>> _______________________________________________
>>>>>>>> QGIS-Developer mailing list
>>>>>>>> QGIS-Developer at lists.osgeo.org
>>>>>>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>>>>>>>> Unsubscribe: https://lists.osgeo.org/mailma
>>>>>>> Alessandro Pasotti
>>>>>>> w3:   www.itopen.it
>>>>>> Alessandro Pasotti
>>>>>> w3:   www.itopen.it
>>>>> “When you travel, remember that a foreign country is not designed to
>>>>> make you comfortable. It is designed to make its own people comfortable."
>>>>> -- Clifton Fadiman
>>>> Alessandro Pasotti
>>>> w3:   www.itopen.it
>>> -- Clifton Fadiman
>> Alessandro Pasotti
>> w3:   www.itopen.it
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Ismail Sunni
> ismailsunni.wordpress.com
Alessandro Pasotti
w3:   www.itopen.it
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20170605/936242d6/attachment.html>
More information about the QGIS-Developer mailing list
