[QGIS-Developer] Lizmap - "Story map" feature POC with QGIS user map data
kimaidou kimaidou at gmail.com
Wed Jun 7 01:24:00 PDT 2017
Hi Tom
I prefer to use a layer as a source, because this way you can use it
* to zoom on somewhere (each layer feature ) -> no need to set up bookmarks
in QGIS
* display some information (title, description, photo, etc.) based on each
feature GetFeatureInfo request
I could use any other lizmap feature based on a layer to add more tools
(such as selection, filter of child data based on the active parent
feature, etc.)
If I base this tool on QGIS bookmarks, I ask the editor to create many
bookmarks, and I cannot find enough information for each bookmark item.
Basing the tool on a simple layer is more flexible in my opinion, since you
are not limited on which information you use for each feature.
Michaël
2017-06-06 20:45 GMT+02:00 Tom Chadwin <tom.chadwin at nnpa.org.uk>:
> Hi Michaël
> Have you thought of basing it on QGIS bookmarks instead? No need to
> dedicate
> a field for the "order" property then.
> Tom
> Buy Pie Spy: Adventures in British pastry 2010-11 on Amazon
> View this message in context: http://osgeo-org.1560.x6.
> nabble.com/QGIS-Developer-Lizmap-Story-map-feature-POC-
> with-QGIS-user-map-data-tp5323217p5323254.html
> Sent from the QGIS - Developer mailing list archive at Nabble.com.
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20170607/3d0594c8/attachment.html>
More information about the QGIS-Developer mailing list
