[QGIS-Developer] Lizmap - "Story map" feature POC with QGIS user map data
Tim Sutton
tim at kartoza.com
Wed Jun 7 23:57:13 PDT 2017
Hi
On Tue, Jun 6, 2017 at 5:16 PM, kimaidou <kimaidou at gmail.com> wrote:
> Hi all,
> I am working on a new feature for upcoming version of Lizmap Web Client,
> which allows the user
> * to move from one layer object to the next , and shows:
> * to see the feature information ( based on Lizmap popup)
> * to see the geometry of the feature (highlighted in yellow) , optionnaly
> The editor of the QGIS project will choose :
> * a coverage layer (same principle as the atlas)
> * a label field used to fill a combo box from the layer features
> * a field used to order the layer features (usually the label field)
> * buttons to move backward/forward, which means to the previous or next
> feature
> * a button to start an animation, with an option to set the step duration
> (5 s by default)
> Changing the user in the combo box will trigger the move to the
> corresponding feature
> I have used QGIS user map data to build a demo
> https://plugins.qgis.org/community-map/
> Please tell me if I have the permission to use this data. Obviously, if
> using this data is not possible, I will shut down the demo !
I don't see any problem with this. Thanks for making more cool things for
the world :-)
Regards
Tim
> The link is
> http://dev.lizmap.3liz.com/index.php/projects/demonstration/qgis_community
> Since this feature is based on a layer, you can imagine other scenarios of
> use.
> Cheers
> Michaël
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
Tim Sutton
Visit http://kartoza.com to find out about open source:
* Desktop GIS programming services
* Geospatial web development
* GIS Training
* Consulting Services
Skype: timlinux Irc: timlinux on #qgis at freenode.net
Tim is a member of the QGIS Project Steering Committee
Kartoza is a merger between Linfiniti and Afrispatial
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20170608/b78b02c8/attachment.html>
