[QGIS-Developer] Lizmap - "Story map" feature POC with QGIS user map data
kimaidou kimaidou at gmail.com
Thu Jun 8 03:09:09 PDT 2017
Thanks Tim !
2017-06-08 8:57 GMT+02:00 Tim Sutton <tim at kartoza.com>:
> Hi
> On Tue, Jun 6, 2017 at 5:16 PM, kimaidou <kimaidou at gmail.com> wrote:
>> Hi all,
>> I am working on a new feature for upcoming version of Lizmap Web Client,
>> which allows the user
>> * to move from one layer object to the next , and shows:
>> * to see the feature information ( based on Lizmap popup)
>> * to see the geometry of the feature (highlighted in yellow) , optionnaly
>> The editor of the QGIS project will choose :
>> * a coverage layer (same principle as the atlas)
>> * a label field used to fill a combo box from the layer features
>> * a field used to order the layer features (usually the label field)
>> * buttons to move backward/forward, which means to the previous or next
>> feature
>> * a button to start an animation, with an option to set the step duration
>> (5 s by default)
>> Changing the user in the combo box will trigger the move to the
>> corresponding feature
>> I have used QGIS user map data to build a demo
>> https://plugins.qgis.org/community-map/
>> Please tell me if I have the permission to use this data. Obviously, if
>> using this data is not possible, I will shut down the demo !
> ​I don't see any problem with this. Thanks for making more cool things for
> the world :-)
> Regards
> Tim​
>> The link is
>> http://dev.lizmap.3liz.com/index.php/projects/demonstration/
>> qgis_community
>> Since this feature is based on a layer, you can imagine other scenarios
>> of use.
>> Cheers
>> Michaël
>> QGIS-Developer mailing list
>> QGIS-Developer at lists.osgeo.org
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Tim Sutton
> Visit http://kartoza.com to find out about open source:
>  * Desktop GIS programming services
>  * Geospatial web development
> * GIS Training
> * Consulting Services
> Skype: timlinux Irc: timlinux on #qgis at freenode.net
> Tim is a member of the QGIS Project Steering Committee
> Kartoza is a merger between Linfiniti and Afrispatial
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20170608/e5c2cbd8/attachment.html>
More information about the QGIS-Developer mailing list
