[QGIS-Developer] Processing algorithms provider and docs
DelazJ
delazj at gmail.com
Wed Jun 21 01:04:07 PDT 2017
Hi Matteo,
As far as I know there is no automatic process to generate/fill a section
in the online documentation for each algorithm added to Processing. Someone
has to be aware of this new algorithm and write its description. And I'm
not sure it has often be the case untill the webhook (which currently
prevents of this new algorithm, so no longer need for manual check). So I'd
say that it's normal to have missing algorithms in the documentation.
Harrissou
2017-06-21 9:43 GMT+02:00 matteo <matteo.ghetta at gmail.com>:
> Hi all,
> Processing is now in big reorganization but also before its porting in
> C++ I noticed some differences between the number of algorithm in the UI
> and those in the website.
> For example, I remember that there were some algorithm in the Database
> menu that involves also SpatiaLite while in the documentation here:
> http://docs.qgis.org/testing/en/docs/user_manual/
> processing_algs/qgis/database.html
> only 2 algorithms appear.
> Is the documentation of he Processing providers (in the website) build
> according to the algorithm number of the UI?
> Thanks for any further info
> Cheers
> Matteo
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20170621/748a0821/attachment.html>
