[QGIS-Developer] Processing 3.0: Possible change to the Convex Hull algorithm
Havard Tveite havard.tveite at nmbu.no
Tue Jun 27 02:26:02 PDT 2017
It is important that convex hull is available for datasets
at the user interface level.
HÃ¥vard
On 27. juni 2017 07:19, Paolo Cavallini wrote:
> Hi Nyall,
> Il 27/06/2017 01:41, Nyall Dawson ha scritto:
>>> This discussion relates to the "Convex Hull" algorithm. I'd like to:
>>> 1. Drop the "Field (optional, only used if creating convex hulls by
>>> classes)" option and the accompanying method choice used to set the
>>> convex hull to 'create convex hulls based on field'.
> I understand the rationale behind this; I'm just a bit worried it will
> be more complicated and less understandable for users.
> Perhaps adding another module that does both commands (collect + convex
> hull) in one shot would be useful?
> All the best.
More information about the QGIS-Developer mailing list
