[QGIS-Developer] Processing 3.0: Possible change to the Convex Hull algorithm
G. Allegri
giohappy at gmail.com
Tue Jun 27 15:12:22 PDT 2017
I understand and agree on having "atomic" algorithms but I'm not sure if we
can always consider single features as the unique operating level. I know
this would bring benefits to the code engineering but we have to keep in
mind the end users expectations.
I agree with Mathias, probably we should have atomic/feature level core
algorithms and "processing algorithms" using them for higher level
structures (datasets) in case they fit the task better.
my 2 cents.
giovanni
Il 27 giu 2017 21:06, "Anita Graser" <anitagraser at gmx.at> ha scritto:
> On Tue, Jun 27, 2017 at 7:45 AM, Matthias Kuhn <matthias at opengis.ch>
> wrote:
>> On 6/27/17 7:19 AM, Paolo Cavallini wrote:
>> > Hi Nyall,
>> > Il 27/06/2017 01:41, Nyall Dawson ha scritto:
>> >>> This discussion relates to the "Convex Hull" algorithm. I'd like to:
>> >>> 1. Drop the "Field (optional, only used if creating convex hulls by
>> >>> classes)" option and the accompanying method choice used to set the
>> >>> convex hull to 'create convex hulls based on field'.
>> > I understand the rationale behind this; I'm just a bit worried it will
>> > be more complicated and less understandable for users.
>> > Perhaps adding another module that does both commands (collect + convex
>> > hull) in one shot would be useful?
>> > All the best.
>> Maybe there is the need to ship some often-used models by default then?
>> Thinking of code complexity and maintainability, it makes much sense to
>> modularize algorithm code as much as possible
> I absolutely understand the reason from an engineering point. From the
> user point - and as someone answering a lot of user questions - it is
> predictable that end users will be confused.
> Idea: Have a warning if a user tries to run the new "convex hull" on a
> dataset with single part geometries?
> Best wishes,
> Anita
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20170628/e5af6187/attachment.html>
