[QGIS-Developer] Processing 3.0: Possible change to the Singlepart to Multipart algorithm
Nyall Dawson
nyall.dawson at gmail.com
Tue Jun 27 15:49:19 PDT 2017
On 27 June 2017 at 15:16, Paolo Cavallini <cavallini at faunalia.it> wrote:
> Il 27/06/2017 02:18, Mathieu Pellerin ha scritto:
>> +1, I'm a regular user of that alg & your proposal makes sense. It'll be
>> useful to have the reduced single to multi geom type within models.
> +1
> unsure it has much meaning for shapefiles though, and this may be
> confusing for users.
> Thanks.
It probably doesn't have any meaning - but is that a problem? You'd
only be using this algorithm if you had a particular requirement for
it (e.g. preparing a result for upload into a PostGIS table which
requires multi geometry types).
Nyall
