[QGIS-Developer] Processing 3.0: Possible change to the Singlepart to Multipart algorithm
G. Allegri
giohappy at gmail.com
Tue Jun 27 16:05:19 PDT 2017
+1 from me, also because "Singlepart to Multipart" means literally that.
giovanni
Il 28 giu 2017 00:49, "Nyall Dawson" <nyall.dawson at gmail.com> ha scritto:
On 27 June 2017 at 15:16, Paolo Cavallini <cavallini at faunalia.it> wrote:
> Il 27/06/2017 02:18, Mathieu Pellerin ha scritto:
>> +1, I'm a regular user of that alg & your proposal makes sense. It'll be
>> useful to have the reduced single to multi geom type within models.
> +1
> unsure it has much meaning for shapefiles though, and this may be
> confusing for users.
> Thanks.
It probably doesn't have any meaning - but is that a problem? You'd
only be using this algorithm if you had a particular requirement for
it (e.g. preparing a result for upload into a PostGIS table which
requires multi geometry types).
Nyall
QGIS-Developer mailing list
QGIS-Developer at lists.osgeo.org
List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20170628/1bde4b49/attachment.html>
