[QGIS-Developer] Processing 3.0: Possible change to the Convex Hull algorithm
    G. Allegri
    giohappy at gmail.com
    Wed Jun 28 01:07:48 PDT 2017
I would set them to null. In general I wouldn't change the dataset fields
schema along the processing steps, except in case of algorithms dedicated
to this.
The same happens with Dissolve.
giovanni
Il 28 giu 2017 09:53, "Nyall Dawson" <nyall.dawson at gmail.com> ha scritto:
> On 28 June 2017 at 14:42, Paolo Cavallini <cavallini at faunalia.it> wrote:
> > If we use the boolean as you suggested, I think the default should
> > probably be all features.
> That's fine by me.
> Incidentally - how should we handle attributes here (and other similar
> algorithms)? Take the first feature's attributes? Drop all attributes?
> Nyall
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20170628/5b1a9810/attachment.html>
