[QGIS-Developer] Processing 3.0: Possible change to the Convex Hull algorithm
G. Allegri
giohappy at gmail.com
Wed Jun 28 01:23:20 PDT 2017
The best of two (but there would be a bit of overhead for the algorithm):
set them to null as soon as two different values are found, keep the first
encountered value otherwise (all the features with same value).
giovanni
2017-06-28 10:16 GMT+02:00 Anita Graser <anitagraser at gmx.at>:
> On Wed, Jun 28, 2017 at 9:53 AM, Nyall Dawson <nyall.dawson at gmail.com>
> wrote:
>> Incidentally - how should we handle attributes here (and other similar
>> algorithms)? Take the first feature's attributes? Drop all attributes?
> I would take the first feature's attributes because I've seen multiple
> times that input datasets for aggregation algorithms (such as hulls,
> dissolve, ...) are prepared in a way that the result represents a certain
> class, e.g. all points where column "type" value is 'tree'. Why should we
> delete the 'tree' value then ...
> Best wishes,
> Anita
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20170628/a9e37f7f/attachment-0001.html>
