[QGIS-Developer] Processing 3.0: Possible change to the Convex Hull algorithm
G. Allegri giohappy at gmail.com
Thu Jun 29 01:21:45 PDT 2017
1. Allowing multiple field selection for grouping
2. Keeping attributes of first feature when grouping
I will accept this criteria, obviously, if it's the preferred solution for
the mosts.
I just want to report that many users (partecipants to courses or
customers) say they find having the "first feature value" misleading.
I agree with them. I would set the field values only for the grouping
fields, having the same value within the group, and set null for the other
fields.
The problem raises during a long workflow. At some point you obtain a
dataset with unconsisten field values, and it's not always obvious to know
when and.which field value was set miningless.
giovanni
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20170629/6c06ca17/attachment-0001.html>
More information about the QGIS-Developer mailing list
