[QGIS-Developer] QGIS project XSD
G. Allegri
giohappy at gmail.com
Fri Jun 30 02:39:50 PDT 2017
> Seems like a huge amount of administrative overhead to me. A small
> change to the project format could result in massive amounts of
> required changes to the xsd.
> Given that now it's safe to have multiple QgsProjects at once,
> couldn't you instead just load the project and retrieve the desired
> information using the QGIS API directly?
Yes Nyall, it's ok until you can use the QGIS API :)
You know that system integration often must rely on standard formats to
exchange information in a decoupled way.
QGIS is more often integrated in heterogeneous environments where it's not
always possible (or it would be an overhead) to install and use QGIS libs.
giovanni
> Nyall
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20170630/e86c3610/attachment.html>
