[Qgis-developer] Processing Gdal Assign and Extract Projection
matteo
matteo.ghetta at gmail.com
Fri Mar 3 10:43:31 PST 2017
Hi all,
I'm running Assign and Extract Projection on some default layers but
actually it seems that the 2 algorithms are not working (nothing happens
even with the "create also .prj file" activated) but no errors appear.
Only in the Processing Log, wit the Assign Projection I get:
2017-03-03T13:31:02 0 gdal_edit.py -a_srs EPSG:3003
/home/matteo/lavori/gis/corso/Dati_corso_QGIS/dtm
2017-03-03T13:31:02 0 GDAL execution console output
ERROR 6: The AIG driver does not support update access to existing
datasets.
so it seems that the algorithm cannot overwrite the original file.
BTW, with 2.18 the prj file is created.
Should I open a ticket?
Thanks
Matteo
