[Qgis-developer] PyQgsServerTest :: test_wms_getprint_srs disabled
Matthias Kuhn
matthias at opengis.ch
Fri Mar 3 23:25:58 PST 2017
Following the conversation from
https://github.com/qgis/QGIS/commit/89d4998 , this is an announcement
to notify that the PyQgsServerTest :: test_wms_getprint_srs has been
disabled.
Work has been underway to remove "noisy" tests from Travis which cause
false alarms and these tests regularly fail for unrelated changes.
False alarms are bad as they undermine confidence in the CI results
and encourage contributors to ignore the test results.
If you're interested in seeing this test continue as part of the CI
infrastructure here's an example of the test failing on an unrelated
commit:
https://travis-ci.org/qgis/QGIS/jobs/207575956
Matthias
