[Qgis-developer] PyQgsServerTest :: test_wms_getprint_srs disabled
Alessandro Pasotti
apasotti at gmail.com
Sat Mar 4 00:18:44 PST 2017
On Sat, Mar 4, 2017 at 8:25 AM, Matthias Kuhn <matthias at opengis.ch> wrote:
> Following the conversation from
> https://github.com/qgis/QGIS/commit/89d4998 , this is an announcement
> to notify that the PyQgsServerTest :: test_wms_getprint_srs has been
> disabled.
> Work has been underway to remove "noisy" tests from Travis which cause
> false alarms and these tests regularly fail for unrelated changes.
> False alarms are bad as they undermine confidence in the CI results
> and encourage contributors to ignore the test results.
> If you're interested in seeing this test continue as part of the CI
> infrastructure here's an example of the test failing on an unrelated
> commit:
> https://travis-ci.org/qgis/QGIS/jobs/207575956
> Matthias
> Qgis-developer mailing list
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
Hi Paul,
can you please have a look?
I'm afraid this failure is not a problem in the test itself but a symptom
of more serious issue: the map is completely missing from the generated
print.
The test was introduced by this commit.
https://github.com/qgis/QGIS/commit/f3a5c98178103afc5da3d7d5d3bc2df6930cb9bc#diff-260b51384025856fac2dc9682481a865R569
Check it with:
https://travis-ci.org/qgis/QGIS/jobs/207575956#L1477
Thanks!
Alessandro Pasotti
w3: www.itopen.it
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20170304/bf645814/attachment.html>
