[Qgis-developer] Changing behaviour of "show selected features" mode for attribute table
Denis Rouzaud
denis.rouzaud at gmail.com
Mon Mar 6 23:42:49 PST 2017
Thanks for the precision.
Then
+1 for showing nothing when no selection
+0 for "show only selected" as default mode.
Le mar. 7 mars 2017 à 08:30, Nyall Dawson <nyall.dawson at gmail.com> a écrit :
> On 7 March 2017 at 17:23, Denis Rouzaud <denis.rouzaud at gmail.com> wrote:
> > I'm a bit confused here.
> > At the moment, there is a global option for attribute table widget "show
> > only selected".
> > If you choose this option and have a selection, you won't have any mean
> to
> > show all the layer unless you deselect and reopen the attribute table
> (hence
> > showing all). In other words, switching between show all and show
> selected
> > only has no effect and shows only selected features.
> > Does your work will fix this i.e. really show all features?
> In current master and 2.18 branch if you set the attribute table to
> show only selected, and then open the table and change the filter in
> the bottom left to "show all", then ALL features will be loaded
> (regardless of the current/original selection)
> Nyall
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20170307/8b9b2918/attachment.html>
