[Qgis-developer] Changing behaviour of "show selected features" mode for attribute table
Nyall Dawson
nyall.dawson at gmail.com
Mon Mar 6 23:30:25 PST 2017
On 7 March 2017 at 17:23, Denis Rouzaud <denis.rouzaud at gmail.com> wrote:
> I'm a bit confused here.
> At the moment, there is a global option for attribute table widget "show
> only selected".
> If you choose this option and have a selection, you won't have any mean to
> show all the layer unless you deselect and reopen the attribute table (hence
> showing all). In other words, switching between show all and show selected
> only has no effect and shows only selected features.
> Does your work will fix this i.e. really show all features?
In current master and 2.18 branch if you set the attribute table to
show only selected, and then open the table and change the filter in
the bottom left to "show all", then ALL features will be loaded
(regardless of the current/original selection)
Nyall
