[Qgis-developer] PyQgsServerTest :: test_wms_getprint_srs disabled
Paul Blottiere
paul.blottiere at oslandia.com
Mon Mar 6 23:48:20 PST 2017
Alessandro,
> do you have clue if the multi-threading rendering could be the root
cause of this issue?
The test is failing on travis for 2.14 too. However, PR about the
replacement of the QgsMapRenderer and the parallel rendering activation
are not backported in 2.14. So, as it happens both on master and 2.14,
it seems to be independent from the rendering step.
Only unit tests on the getprint service has been backported and before
that, there was none. So I think that the failing test is just
underlying an old issue which was there even before we started to
refactor the server.
What do you think?
Paul
On 03/07/2017 08:16 AM, Alessandro Pasotti wrote:
> On Mon, Mar 6, 2017 at 5:30 PM, Paul Blottiere
> <blottiere.paul at gmail.com <mailto:blottiere.paul at gmail.com>> wrote:
> Hi Alessandro,
>>> can you please have a look?
>>> I'm afraid this failure is not a problem in the test itself but
>>> a symptom of more serious issue: the map is completely missing
>>> from the generated print.
>> FYI, the same test also fails on 2.14 as discussed on the
>> following commit:
> I took a look but I cannot reproduce the failing test
> test_wms_getprint_srs.
> Actually, I have tested it within the next environment without issues:
> - master on Debian
> - release-2_14 on Ubuntu.
> Can anyone confirm?
> Paul
> Paul,
> Thanks for looking into this, I'll do some local testing shortly, do
> you have clue if the multi-threading rendering could be the root cause
> of this issue?
> A s a side note, I would recommend to refactor the server test and
> split it in smaller dedicated tests for the different services.
> Alessandro Pasotti
> w3: www.itopen.it <http://www.itopen.it>
> Qgis-developer mailing list
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20170307/7069780f/attachment-0001.html>
