[Qgis-developer] Wiki page/area for 'Building QGIS from scratch'
André William
wss.andre at gmail.com
Fri Mar 17 10:08:32 PDT 2017
Thanks for the input, Matthias.
It's been some time since I built it from scratch, so I wouldn't be able to
provide specifics. But it was on Ubuntu 16, and Mark's comments about Qt5,
QScintylla and libpng did ring a bell for me, since the email.
I'll try again on the next couple of days and if there's interest I can
report on how it went.
André
2017-03-17 13:29 GMT-03:00 Matthias Kuhn <matthias at opengis.ch>:
> Hi André and Mark,
> Can you clarify on which systems you are working and which dependencies
> cause headaches?
> In many situations, a build of Qt is not required and doing this
> requires deep understanding of all the involved libraries. I would
> strongly advice anyone to first explore other alternatives before
> starting the walk on this tricky road.
> For reference, here is a set of script that is able to build many of the
> dependencies (into a custom root path) for those who still want to do it:
> https://github.com/opengisch/osgeo4travis/tree/master/docker/qt5/scripts
> Best regards
> Matthias
> On 03/17/2017 05:17 PM, André William wrote:
> > Hi all, my name is André, this is my first email on this list.
> > I've also struggled with building QGIS before, and besides the problems
> > mentioned by Mark, the default installed libraries are often
> > incompatible with QGIS or some of its dependencies.
> > I'd be willing to help with documenting my steps or possibly
> > contributing code to the scripts as I attempt to build on a clean OS.
> > André
> > 2017-03-17 12:26 GMT-03:00 Matthias Kuhn <matthias at opengis.ch
> > <mailto:matthias at opengis.ch>>:
> > Hi Mark,
> > Are the dependencies not available for your distribution?
> > Except for some very special systems (Android, very old ubuntu
> versions
> > on travis...) I never ever build these dependencies manually and just
> > install them.
> > Matthias
> > On 03/17/2017 04:21 PM, Mark Johnson wrote:
> > > For the last 10 days I have been attempting to build QGIS 3.0
> master
> > > from scratch.
> > > For this QT 5 also had to be build, which is not an easy task.
> > > In the past I had used the 'run' scripts, which installed the
> source
> > > - qt-opensource-linux-x64-5.7.1.run
> > > but after the first installment I noticed that QGIS needed a modal
> that
> > > had not been included: QtWebKit
> > > The there is QScintilla,PyQt5 (with sip) and Qwt
> > > - Qwt: did not install the libs where PyQt5 could not find it
> > > - QScintilla did not accept the –-pyqt=PyQt5 parameter, so
> > > the configure.py had to be adapted
> > > And then there is the cmake of QGIS3 itself, which in itself is a
> horror
> > > dream come true
> > > - instead of asking *once* for the 'Qt5 cmake' directory
> > > -- it asks it about 12 times for the 17 modals needed
> > > --> I assume ccmake determines for each module the dependencies,
> > but for
> > > the user this is a horrible - time consuming experience
> > > For this reason I think it would be a good idea to add an area in
> the
> > > QGIS wiki with tip how this should be done,
> > > Based on a specific QGIS version
> > > - which other versions (QT5, python3 [python 3.5.3rc1 does not
> work,
> > > python 3.4.6 does] etc.) should be used
> > > - basic howto's to
> > > -- build QT5 from scratch (like using git that contains QtWebKit,
> as
> > > apposed to the 'run' that does not)
> > > -- known irregularities
> > > ---> copy the Qwt/libs to the Qt5/libs so that PyQt5 can find them
> > > ---> QScintilla how to adapt the configure.py script to create the
> > > needed PyQt5 version
> > > The goal would be to offer a guideline for those doing this for the
> > > first time
> > > - avoiding known traps
> > > Something in the form of (based on the present wiki):
> > > Organize an event
> > > Collaborative documents
> > > Building QGIS 3.0 from scratch
> > > Building QT 5 from scratch
> > > Building and correctly installing Qwt
> > > Building QScintilla for PyQt5
> > > Building PyQt5
> > > QGIS3 ccmake
> > > I would be willing to start this with my experiences.
> > > Mark Johnson, Berlin Germany
> > > _______________________________________________
> > > Qgis-developer mailing list
> > > Qgis-developer at lists.osgeo.org <mailto:Qgis-developer at lists.
> osgeo.org>
> > > List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> > <https://lists.osgeo.org/mailman/listinfo/qgis-developer>
> > > Unsubscribe:
> osgeo.org>
> > Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20170317/a4460779/attachment.html>
