[Qgis-developer] Wiki page/area for 'Building QGIS from scratch'
Matthias Kuhn
matthias at opengis.ch
Fri Mar 17 09:29:27 PDT 2017
Hi André and Mark,
Can you clarify on which systems you are working and which dependencies
cause headaches?
In many situations, a build of Qt is not required and doing this
requires deep understanding of all the involved libraries. I would
strongly advice anyone to first explore other alternatives before
starting the walk on this tricky road.
For reference, here is a set of script that is able to build many of the
dependencies (into a custom root path) for those who still want to do it:
https://github.com/opengisch/osgeo4travis/tree/master/docker/qt5/scripts
Best regards
Matthias
On 03/17/2017 05:17 PM, André William wrote:
> Hi all, my name is André, this is my first email on this list.
> I've also struggled with building QGIS before, and besides the problems
> mentioned by Mark, the default installed libraries are often
> incompatible with QGIS or some of its dependencies.
> I'd be willing to help with documenting my steps or possibly
> contributing code to the scripts as I attempt to build on a clean OS.
> André
> 2017-03-17 12:26 GMT-03:00 Matthias Kuhn <matthias at opengis.ch
> <mailto:matthias at opengis.ch>>:
> Hi Mark,
> Are the dependencies not available for your distribution?
> Except for some very special systems (Android, very old ubuntu versions
> on travis...) I never ever build these dependencies manually and just
> install them.
> Matthias
> On 03/17/2017 04:21 PM, Mark Johnson wrote:
> > For the last 10 days I have been attempting to build QGIS 3.0 master
> > from scratch.
> > For this QT 5 also had to be build, which is not an easy task.
> > In the past I had used the 'run' scripts, which installed the source
> > - qt-opensource-linux-x64-5.7.1.run
> > but after the first installment I noticed that QGIS needed a modal that
> > had not been included: QtWebKit
> > The there is QScintilla,PyQt5 (with sip) and Qwt
> > - Qwt: did not install the libs where PyQt5 could not find it
> > - QScintilla did not accept the –-pyqt=PyQt5 parameter, so
> > the configure.py had to be adapted
> > And then there is the cmake of QGIS3 itself, which in itself is a horror
> > dream come true
> > - instead of asking *once* for the 'Qt5 cmake' directory
> > -- it asks it about 12 times for the 17 modals needed
> > --> I assume ccmake determines for each module the dependencies,
> but for
> > the user this is a horrible - time consuming experience
> > For this reason I think it would be a good idea to add an area in the
> > QGIS wiki with tip how this should be done,
> > Based on a specific QGIS version
> > - which other versions (QT5, python3 [python 3.5.3rc1 does not work,
> > python 3.4.6 does] etc.) should be used
> > - basic howto's to
> > -- build QT5 from scratch (like using git that contains QtWebKit, as
> > apposed to the 'run' that does not)
> > -- known irregularities
> > ---> copy the Qwt/libs to the Qt5/libs so that PyQt5 can find them
> > ---> QScintilla how to adapt the configure.py script to create the
> > needed PyQt5 version
> > The goal would be to offer a guideline for those doing this for the
> > first time
> > - avoiding known traps
> > Something in the form of (based on the present wiki):
> > Organize an event
> > Collaborative documents
> > Building QGIS 3.0 from scratch
> > Building QT 5 from scratch
> > Building and correctly installing Qwt
> > Building QScintilla for PyQt5
> > Building PyQt5
> > QGIS3 ccmake
> > I would be willing to start this with my experiences.
> > Mark Johnson, Berlin Germany
> > Qgis-developer mailing list
> > Qgis-developer at lists.osgeo.org <mailto:Qgis-developer at lists.osgeo.org>
> > List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> <https://lists.osgeo.org/mailman/listinfo/qgis-developer>
> > Unsubscribe:
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
