[Qgis-developer] QGIS crashes when zzoming in
    Jorge Gustavo Rocha
    jgr at di.uminho.pt
    Sat Mar 25 16:36:19 PDT 2017
Hi Jonathan,
The problem you mentioned related to "style by category" in a specific
project [1] maybe related with this thread.
As far as I know, you didn't submit the bug report yet. Maybe the
problem was fixed with Nyall's PR [2], but it might help if you submit
the bug report along with your project file. If you can't share your
data publicly, add the bug report and then make the data available just
for the developers for testing upon request.
Regards,
Jorge
[1] https://lists.osgeo.org/pipermail/qgis-user/2017-March/039520.html
[2] https://github.com/qgis/QGIS/pull/4300
Às 22:36 de 25-03-2017, Nyall Dawson escreveu:
> On 25 March 2017 at 19:00, Paolo Cavallini <cavallini at faunalia.it> wrote:
>> Il 23/03/2017 16:39, Matthias Kuhn ha scritto:
>>> Hi Paolo,
>>> a backtrace would still help a LOT more. Can you provide one?
>> Done:
>> http://hub.qgis.org/issues/16377
>> I cannot distribute the original data in public, but can make it
>> available for testing.
>> The crash is very consistent.
> I've seen similar crashes lately too. I thought it was limited to the
> categoried renderer (hence https://github.com/qgis/QGIS/pull/4300),
> but seems not from your backtrace.
> Problem is that I can't reliably reproduce this. Sometimes things are
> fine, sometimes crashes happen frequently. If you have a project you
> can reliably reproduce this with can you send it through?
> Nyall
> Qgis-developer mailing list
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
J. Gustavo
Jorge Gustavo Rocha
Departamento de Informática
Universidade do Minho
4710-057 Braga
Tel: +351 253604480
Fax: +351 253604471
Móvel: +351 910333888
skype: nabocudnosor
