[Qgis-developer] [Qgis-psc] bug tracker cleanup
Paolo Cavallini
cavallini at faunalia.it
Mon Mar 27 23:38:50 PDT 2017
Hi Giovanni,
Il 27/03/2017 12:02, Giovanni Manghi ha scritto:
> this thread didn't get the traction I was hooping for, is this a
> indication that is a general opinion that all the fixing effort should
> be focused on qgis3 and not also on the next LTR?
agreed, I'm also surprised (the list seems less reactive on several
subjects lately), and thanks for your perseverance in tracking this
important issue.
>> it makes sense to me. how many do you think are important to fix?
>> how many affect 2.18 only, not 3?
> during my cleanup a couple of weeks ago I clearly separated the
> regressions affecting only master/qgis3 and the ones only affecting
> 2.18.*. In the second case I tried to my best to also try clearly
> separate the ones we know since more or less long time and the ones
> that have appeared after 2.14.
> The following list is a sample of important things (to me) that have
> regressed in 2.18 since 2.14:
> 16242 QGIS 2.18.4 saves always with absolute paths
> 15961 Escaping out of Dialog causes QGIS to crash
> 15803 2.18: Move Selection to Top not working in attribute table
> 15976 Attribute table: rows are switching when adding attributes
> 16302 Quick calculation bar causes QGIS crash when updating fields with aliases
> 16186 Broken Processing/GRASS tools under Windows > this is a
> packaging issue and not a Processing one
> 15868 Frequent errors in DB Manager: `pyqtSignal must be bound to a
> QObject, not 'PGVectorTable'`
> 16295 DB Manager: error importing data into GPKG connections
> 16296 Cannot use anymore d&d to import a layer from Spatialite in PostGIS
> 16297 (macOS) layers imported into a Spatialite Database with DB
> manager are not recognized as spatial tables
> 15741 PostGIS issue when using 'Merge selected features' tool
> (Geometry type does not match column type) > this is very bad as
> causes data loss
> 15974 Rows of the attribute table seem to be duplicated when saving
> edits in a shapefile
bad stuff indeed. so the above does not hit Q3, right?
a bit of a pity investing on a dead branch rather than on main trunk,
but I think it is a necessity, now that we want 2.18 as LTR.
> The developer meeting is in 1 month time. I would like to discuss
> *now* a few cleanups so we don't have to do it in Essen and there I
> can use my time to put them in action.
agreed
> * the platform version is very old (2010), can we try upgrade it? If
> someome provides me with a copy of the db I would give it a go on a
> testbench
> * remove all the projects others than "QGIS Application" from
> http://hub.qgis.org/projects
it makes sense, but in spipte of our efforts, many plugins still rely on
this, and I do not think it's a good move just to shut them down
> * close all tickets that were last updated/commented more than... 2/3/4 years?
not sure about this: if they still make sense, I'd prefer to keep them.
e.g. the second oldest is still valid, and helps us remembering about a
real issue:
http://hub.qgis.org/issues/167
I understand keeping the list short is a major advantage, but removing
issues like this is not an advantage for the project IMHO.
All the best.
Paolo Cavallini - www.faunalia.eu
QGIS & PostGIS courses: http://www.faunalia.eu/training.html
https://www.google.com/trends/explore?date=all&geo=IT&q=qgis,arcgis
