[Qgis-developer] automatic sip files generation
Denis Rouzaud
denis.rouzaud at gmail.com
Thu Mar 30 08:02:03 PDT 2017
Le jeu. 30 mars 2017 à 16:56, Tim Sutton <tim at kartoza.com> a écrit :
> Hi
> On 30 Mar 2017, at 3:18 PM, Denis Rouzaud <denis.rouzaud at gmail.com> wrote:
> Dear all,
> I'd like to raise the attention on a new workflow I just merged to
> automatically generate SIP files using the header as source only.
> A PR is pending for the documentation, but you can read it here
> https://github.com/3nids/QGIS-Documentation/blob/6e3a9fb6f98a2869aef27c01b7ab70eb0a4c7556/source/docs/developers_guide/codingstandards.rst#sip-bindings
> (waiting to be merged).
> For the moment, only 3 files are generated (qgsattributes, qgsfeature and
> qgsvectorlayer). One can starts adding new files to the process by adapting
> their header and removing them from python/auto_sip.blacklist.
> This is really great! A couple of questions:
> 1) the blacklist implies that any new .h files added to the source tree
> will automatically have sip bindings generated unless you explicitly
> blacklist them?
As soon as you add the include in python/core/core.sip (or gui, analysis),
the SIP is considered as automatically generated from header except if you
blacklist it.
> 2) are you thinking to maintain the sip files in Git still or remove the
> from revision in favour of having them as build time artifacts only? I ask
> this because I often direct people to use the sip files as a reference
> guide for the python API if they want to dig under the hood a bit more.
The goal is to remove the SIP files and have them created on build time.
But:
1) I except a few errors in the script to arise (so better to have an easy
access to the SIP files)
2) it needs to reach a significant point of ported headers.
So, in a somehow close or far future, yes they'll be removed from source
(hence no blacklist anymore only manual files such as core/conversions.sip).
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20170330/f2e016b5/attachment.html>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20170330/f2e016b5/attachment.jpg>
