[QGIS-Developer] Expression Functions: Where are they used in QGIS Desktop? Which ones won't work "outside"?
Nathan Woodrow madmanwoo at gmail.com
Tue May 9 04:48:14 PDT 2017
Hey Tom and Victor,
I'm happy for you to do whatever want with qgis2js. I can give you full
repo write access if you wish to improve it.  I mainly started it to help
Tom and it kind of turned into a cool side project but I don't have any
real use for it.
Regards,
Nathan
On Mon, May 8, 2017 at 8:58 PM, Tom Chadwin <tom.chadwin at nnpa.org.uk> wrote:
> Hi Victor
> I did do a PR for my few local additions:
> https://github.com/NathanW2/qgs2js/pull/2
> It would be good to maintain it as an independent repo, if you can be
> bothered to merge your additions back. Nathan, if you don't want to
> maintain
> it, I'd be happy to take it over, or Victor could.
> As for how I pull it in, I tried using a git submodule, but I couldn't get
> it to work very well in all conditions (such as in Travis). That's why I
> manually copied it in. If you have a better solution, do tell.
> I'm reluctant to use eg pip, as it's a barrier to non-tech users. Anyway, I
> know the question of plugin dependencies has been debated here before, and
> I'm not sure a good solution was proposed.
> Thanks
> Tom
> Buy Pie Spy: Adventures in British pastry 2010-11 on Amazon
> View this message in context: http://osgeo-org.1560.x6.
> nabble.com/QGIS-Developer-Expression-Functions-Where-
> are-they-used-in-QGIS-Desktop-Which-ones-won-t-work-outsid-
> tp5319646p5319716.html
> Sent from the QGIS - Developer mailing list archive at Nabble.com.
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20170509/dac1320c/attachment-0001.html>
More information about the QGIS-Developer mailing list
