[QGIS-Developer] Expression Functions: Where are they used in QGIS Desktop? Which ones won't work "outside"?
Tom Chadwin
tom.chadwin at nnpa.org.uk
Mon May 8 03:58:10 PDT 2017
Hi Victor
I did do a PR for my few local additions:
https://github.com/NathanW2/qgs2js/pull/2
It would be good to maintain it as an independent repo, if you can be
bothered to merge your additions back. Nathan, if you don't want to maintain
it, I'd be happy to take it over, or Victor could.
As for how I pull it in, I tried using a git submodule, but I couldn't get
it to work very well in all conditions (such as in Travis). That's why I
manually copied it in. If you have a better solution, do tell.
I'm reluctant to use eg pip, as it's a barrier to non-tech users. Anyway, I
know the question of plugin dependencies has been debated here before, and
I'm not sure a good solution was proposed.
Thanks
Tom
Buy Pie Spy: Adventures in British pastry 2010-11 on Amazon
View this message in context: http://osgeo-org.1560.x6.nabble.com/QGIS-Developer-Expression-Functions-Where-are-they-used-in-QGIS-Desktop-Which-ones-won-t-work-outsid-tp5319646p5319716.html
Sent from the QGIS - Developer mailing list archive at Nabble.com.
