[QGIS-Developer] [Qgis-developer] Processing toolbox SAGA not working
René-Luc Dhont
rldhont at gmail.com
Wed May 10 02:05:44 PDT 2017
The SAGA LTR is 2.3.*
I have fix some issues with this version, about gdal_io and
flow_accumulation, to use it on ubuntu.
* https://github.com/qgis/QGIS/pull/4294
* https://github.com/qgis/QGIS/pull/4296
* https://github.com/qgis/QGIS/pull/4297
Regards,
René-Luc
Le 10/05/2017 à 10:13, matteo a écrit :
> Hi Giovanni,
> I'm sneaking into this thread...
> On a linux machine and QGIS master, Processing reads only 1 algorithm of
> SAGA. Current version of SAGA installed is 2.3.1
> On sourceforge [0] I now see that SAGA version 4 (?!?) is already
> available. As I remember Processing will support the LTR version of
> SAGA... I'm confused on which version is (or will be) the LTR..
> If the version supported by Processing is different from the one
> provided by the repositories (in my case 2.3.1) do I need to compile the
> correct version by myself or in future the LTR version will be included
> in the repo and packages?
> Thanks for any clue!
> Cheers
> Matteo
> [0] https://sourceforge.net/projects/saga-gis/files/
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
