[QGIS-Developer] Problems building 2.18 on Windows 7 with MS Visual C++ 2010 Express
David Adler
dadler at adtechgeospatial.com
Mon May 22 14:58:52 PDT 2017
I haven't tried building QGIS for over a year and the build process is
now failing.
1. Forked and cloned a clean copy of release-2_18
2. Ran cmake-gui which had the following warning messages but the
Configure and Generate seemed successful
CMake Warning at CMakeLists.txt:320 (FIND_PACKAGE):
By not providing "FindQJSON.cmake" in CMAKE_MODULE_PATH this project has
asked CMake to find a package configuration file provided by "QJSON", but
CMake did not find one.
Could not find a package configuration file provided by "QJSON" with any of
the following names:
QJSONConfig.cmake
qjson-config.cmake
Add the installation prefix of "QJSON" to CMAKE_PREFIX_PATH or set
"QJSON_DIR" to a directory containing one of the above files. If "QJSON"
provides a separate development package or SDK, be sure it has been
installed.
3. Opened the VS project file in qgisbuild and ran BUILD_ALL which had 7
failures like the following:
98> Building Custom Rule
J:/QGISDB2-218/python/pyplugin_installer/CMakeLists.txt
98> CMake does not need to re-run because
E:\qgisbuild\python\pyplugin_installer\CMakeFiles\generate.stamp is
up-to-date.
98> Generating ui_qgsplugininstallerfetchingbase.py
98> Traceback (most recent call last):
92> qgis_doublespinbox.vcxproj ->
E:\qgisbuild\output\bin\RelWithDebInfo\qgis_doublespinbox.exe
98> File "J:\QGISDB2-218\scripts\\pyuic-wrapper.py", line 26, in <module>
98> import qgis.PyQt.uic.pyuic
98> File "E:\qgisbuild\output\python\qgis\__init__.py", line 27, in
<module>
98> from qgis.core import QgsFeature, QgsGeometry
98> File "E:\qgisbuild\output\python\qgis\core\__init__.py", line 30,
in <module>
98> from qgis._core import *
98> ImportError: DLL load failed: The specified module could not be found.
98>C:\Program Files
(x86)\MSBuild\Microsoft.Cpp\v4.0\Microsoft.CppCommon.targets(151,5):
error MSB6006: "cmd.exe" exited with code 1.
Is there something obvious missing or wrong version of some build software?
This email has been checked for viruses by Avast antivirus software.
https://www.avast.com/antivirus
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20170522/b82c70f9/attachment-0001.html>
