[QGIS-Developer] Qt Designer Cannot Drop Widgets onto QgsDockWidget
Luigi Pirelli luipir at gmail.com
Tue May 23 13:34:19 PDT 2017
do you have the hierarchy of the compound widget (usually on the upper
left) ? it should contain a layout => select and break it... this is
theoretically. I'll check how is composed a QgsDockWidget.
Luigi Pirelli
* Boundless QGIS Support/Development: lpirelli AT boundlessgeo DOT com
* LinkedIn: https://www.linkedin.com/in/luigipirelli
* Stackexchange: http://gis.stackexchange.com/users/19667/luigi-pirelli
* GitHub: https://github.com/luipir
* Mastering QGIS 2nd Edition:
* https://www.packtpub.com/big-data-and-business-intelligence/mastering-qgis-second-edition
On 23 May 2017 at 20:24, C Hamilton <adenaculture at gmail.com> wrote:
> Break layout is grayed out and it not selectable.
> On Tue, May 23, 2017 at 2:09 PM, Luigi Pirelli <luipir at gmail.com> wrote:
>> bloke the layout to add any widget to a predefined layout (right
>> click->lay out->brake layout)
>> Luigi Pirelli
>> On 23 May 2017 at 17:01, C Hamilton <adenaculture at gmail.com> wrote:
>> > If I start with a QgsDockWidget in Qt Designer rather than a
>> > QDockWidget, I
>> > cannot add another widget to it. With QDockWidget I have a QWidget
>> > inside
>> > and then all of the other components. I simply cannot add anything to
>> > QgsDockWidget. Is anyone else having the same problem?
>> > I am using the latest version (2.18.8) shipped with the OSGeo4W
>> > installer on
>> > Windows 7.
>> > Thanks,
>> > Calvin
>> > _______________________________________________
>> > QGIS-Developer mailing list
>> > QGIS-Developer at lists.osgeo.org
>> > List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> > Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
More information about the QGIS-Developer mailing list
