[QGIS-Developer] QGIS 3D Grant
Syd Visser
sydv at sjgeophysics.com
Wed May 24 09:25:42 PDT 2017
Martin
Thanks for the clarification. We look forward to seeing better 3D
support more integrated into Qgis. Without good 3D support people here
keep moving back to commercial software.
Unfortunately as far as i can see PostGIS supports 3D vector and 3D
point clouds 2D raster but not 3D raster. The only opensource database
program that I know of that supports 3D raster is Grass which we use for
that purpose. But we usually do our viewing in Paraview or Mayavi
therefore to be able to view in QGIS would be a read advantage.
Keep up the good work on QGIS it is really getting very good.
thanks
Syd
*Syd (Sipke) Visser, P.Geo.*
President, Snr. Geophysicist/Geologist
Tel: 1 (604) 582-1100
Cell: 1 (604) 813-1440
www.sjgeophysics.com <http://www.sjgeophysics.com>
On 2017-05-23 08:40 PM, Martin Dobias wrote:
> Hi Syd
> The idea is to have support for proper 3D meshes/volumes, not just
> 2.5D geometries. The initial work should introduce interface for 3D
> renderers (somehow similar to 2D renderers we have now) allowing
> generation of arbitrary meshes and associated materials from input
> data (which could be 2D geometries, 2.5D geometries or 3D geometries)
> - to create e.g. buildings extruded from their footprint, tree objects
> from points or underground pipes from linestring geometries. In the
> initial work we may not have support for reading true 3D geometries
> from data sources like PostGIS, but that should not be a problem to
> add at some point later when the 3D rendering framework is in place.
> Regards
> Martin
> On Tue, May 23, 2017 at 10:41 PM, Syd Visser <sydv at sjgeophysics.com> wrote:
>> I have a question on the 3D that was proposed in the grant for the use with
>> QT 3D. Am i wrong to think this is really oriented towards what some people
>> call 2.5D (terrain model as shown in the proposal example) or will there be
>> support for 3D that will be able to display 3D meshes or volumes like those
>> available in Grass and display in programs such as NVIZ and Paraview or more
>> advanced commercial software. As geophysicists we are always trying to look
>> at things under the ground not on top.
>> thanks
>> Syd
>> QGIS-Developer mailing list
>> QGIS-Developer at lists.osgeo.org
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20170524/a87075e1/attachment.html>
