[QGIS-Developer] A Couple of Plugin Ideas
C Hamilton
adenaculture at gmail.com
Fri May 26 06:57:10 PDT 2017
Yes I use Anita's TimeManager. What the time manager does is to visualize
across time. What I am proposing is to be able to define a path on the map
and to animate traveling across it. It will be even cooler once we get 3D.
This can be used to create an animation that can include zooming in and out
of an area and to travel along a predefined path.
On Thu, May 25, 2017 at 10:21 PM, Ganeshkumar Shanmugam <ganesh at geoicon.com>
wrote:
> hi
> Geospatial Animator
>> What I am thinking of is a plugin where you can define a series key
>> locations keeping track of the (X,Y) coordinate and zoom level.
>> Additionally there would be a step size and it would output either
>> rendered frames or a video.
> Have you looked at this plugin? some similarity...
> https://anitagraser.com/projects/time-manager/
> Ganesh
> On Fri, May 26, 2017 at 3:53 AM, C Hamilton <adenaculture at gmail.com>
> wrote:
>> I have been toying with writing a couple of QGIS plugins and wanted to
>> check to see if anyone else is doing something similar and to see if there
>> is interest.
>> 1. Geospatial Animator
>> Additionally there would be a step size and it would output either rendered
>> frames or a video.
>> 2. Another Measure Tool
>> As a preface I was looking at some old archaeological records and it was
>> giving site locations based off of the previous location with a distance
>> and bearing. As far as I can tell there is no tools that interactively
>> gives both of these values.
>> I would like a measure tool that provides the distance between points A &
>> B, the bearing from point A to B, and the bearing from point B to A.
>> I would appreciate any thoughts you have or whether someone is already
>> working on this.
>> Thanks,
>> Calvin
>> QGIS-Developer mailing list
>> QGIS-Developer at lists.osgeo.org
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20170526/55d845d9/attachment.html>
