[QGIS-Developer] A Couple of Plugin Ideas
Ganeshkumar Shanmugam
ganesh at geoicon.com
Thu May 25 19:21:41 PDT 2017
hi
Geospatial Animator
> What I am thinking of is a plugin where you can define a series key
> locations keeping track of the (X,Y) coordinate and zoom level.
> Additionally there would be a step size and it would output either
> rendered frames or a video.
Have you looked at this plugin? some similarity...
https://anitagraser.com/projects/time-manager/
Ganesh
On Fri, May 26, 2017 at 3:53 AM, C Hamilton <adenaculture at gmail.com> wrote:
> I have been toying with writing a couple of QGIS plugins and wanted to
> check to see if anyone else is doing something similar and to see if there
> is interest.
> 1. Geospatial Animator
> Additionally there would be a step size and it would output either rendered
> frames or a video.
> 2. Another Measure Tool
> As a preface I was looking at some old archaeological records and it was
> giving site locations based off of the previous location with a distance
> and bearing. As far as I can tell there is no tools that interactively
> gives both of these values.
> I would like a measure tool that provides the distance between points A &
> B, the bearing from point A to B, and the bearing from point B to A.
> I would appreciate any thoughts you have or whether someone is already
> working on this.
> Thanks,
> Calvin
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20170526/900fd128/attachment.html>
