[QGIS-Developer] [Qgis-user] A Couple of Plugin Ideas
C Hamilton
adenaculture at gmail.com
Fri May 26 07:28:31 PDT 2017
I would prefer that. I am not sure how to proceed and for the next two
weeks I will be working with QGIS, but after that I would like to discuss
this further. In the past I have used C/C++ quite extensively, but have not
for the past 5 years. I think I can pick it back up fairly easily. The
biggest hurdle for me is to know how to get a QGIS environment set up and
to make changes to the core QGIS. Mostly this is because I just have not
had the time to investigate what needs to be done. I would like working
with someone who already knows how to do this.
Thanks!!!
On Thu, May 25, 2017 at 5:39 PM, Nyall Dawson <nyall.dawson at gmail.com>
wrote:
> On 26 May 2017 at 05:53, C Hamilton <adenaculture at gmail.com> wrote:
> > I would like a measure tool that provides the distance between points A
> & B,
> > the bearing from point A to B, and the bearing from point B to A.
> This certainly sounds useful!
> I'm wondering - instead of adding this as a plugin, how about adding
> it into the default QGIS measure tool instead? I'm happy to help out
> with mentoring c++ changes if you need it.
> Nyall
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20170526/c8c46813/attachment-0001.html>
