[QGIS-Developer] Problem with "no Data value" with rasters when using the Layer Styling panel?
Stéphane Henriod
stephanebek at gmail.com
Mon May 29 22:45:27 PDT 2017
PS: screencast to better explain the issue: https://vimeo.com/219467091
Le mardi 30 mai 2017, Stéphane Henriod <stephanebek at gmail.com> a écrit :
> Hi
> I am testing the layer styling panel (shortcut F7) with the latest Nightly
> build on the Ubuntu repositories.
> By default, the NoData value is -9999. If I add "10" as additional NoData
> value, nothing happens.
> If I do the same in the layer properties, then the expected behavior
> happens: all pixels with value "10" are not rendered.
> So it seems that the manually added NoData values in the Layer Styling
> Panel are not considered.
> Can someone else replicate this problem? Should I open a ticket?
> Cheers
> Stéphane
> “When you travel, remember that a foreign country is not designed to make
> you comfortable. It is designed to make its own people comfortable." --
> Clifton Fadiman
Clifton Fadiman
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20170530/78b93d55/attachment.html>
