[QGIS-Developer] SIP coverage test removal and Travis optimization
Nyall Dawson
nyall.dawson at gmail.com
Wed May 31 14:14:32 PDT 2017
On 31 May 2017 at 22:15, Denis Rouzaud <denis.rouzaud at gmail.com> wrote:
> Dear all,
> Our automatic SIP files generation is almost there and I would like to
> remove the SIP coverage test from running on Travis.
> Is this acceptable?
In general, but...
> Is there any reason to keep the test (running on Travis)?
There's 2 extra things the sip coverage test does which the sipify test doesn't:
1. Flags if a class is totally missing from the bindings. The sipify
test can't detect when someone's added a new header to the project
without adding a corresponding .sip include to the
core/gui/server/analysis.sip files. Ideally this would be fixed with
some cmake magic which avoids the need to even manually build the
core.sip/gui.sip/etc files...
2. Checks that the methods *are* actually accessible in the Python
bindings. Occasionally there'll be weird things where even though a
method is correctly listed in the .sip files, it just doesn't exist in
the Python library. There's no pattern here - it happens differently
on different platforms. But this is a sip bug, so I don't really care
if we lose this extra check.
For me 1 would need to be addressed before we can drop the test.
Nyall
